tw15 3 point will not lift
rockyw
New User
this tractor has been sittin a few years once I got it started the 3 point worked fine I had to fix a few little problems . but now the 3 point wont move . any help would be great mabey a valve is stuck or something cant find any thing on line pressure test ports ect
I drained the hyd fluid and replaced fluid and filters system is full by the dip stick could the hyd pump have an air lock in it ? thanks for any help roc
good point,, make sure remotes are in center and acs valve is pushed down so you dont bypass the 3 point. I have seen acs valves pulled up at auctions to make the 3 point not work so the tractor will have less bidders... I have found solder wire on the oil sending units to ground to make the oil lights stay on...
But I also see the control valves stick as well so running it and bouncing it will do some good....
