It runs! Well it idles. I think I need to do the carb next. The FEL works - raised it about a foot and it took 4 or 5 hours to drop a few inches when it wasn't running. Clutch and tranny seem ok. Couldn't move the PTO lever but I could before so I probably don't know what I am doing . Centrifugal advance was rust seized.
Couple of questions:
Can rust freeze the governor mechanism? (Not sure there is a problem there, just asking in case.)
Which plug do I remove to bleed the hydraulic pump? There are two on the top - I think it's a piston pump (1957 going by the serial #).
TIA
TIA
