The 3-point lift on my 850 works well in terms of raising and carrying a load without dropping, and with implements that require the lift to be fully lowered and engage the ground with their full weight such as a disc or blade. Trying to use the position control in between is another story. I can generally get the implement to the level I need, but not smoothly. I basically have to raise it above my target height, lower the lift lever until the arms start to drop, and then "catch" the implement where I want it by raising the lift lever to stop its fall. This works, but it sometimes takes a couple of tries.
The draft control lever moves between draft and position control, but is VERY stiff. Not so stiff that I have to use a wrench or a hammer to move it, but much stiffer than I would expect (I don't have another tractor to compare it to). I can't say for sure that there is a big difference in the lift's behavior between draft and position control, but I'm not exactly sure what to look for.
I need (want badly) to get the position control working more smoothly before summer, but I'm not sure where to start. I assume my first step is going to be pulling the hydraulic lift cover. Can somebody point me in the right direction? Also, what parts am I almost certain to need? The http://www.yesterdaystractors.com/Ford-800_Hydraulic-Lift-Cover-Repair-Kit_LCRK5564.html seems like a good start.
Thanks.
Thanks.
