My 1959 871 SOS loses power when in gear and the engine dies. Sometimes this happens when I use the front end loader and most of the time it happens when I put it in R1 (low reverse) and in R2, and in gears 1-3.
It get's better sometimes when I am able to run the tractor through the gears and work it in and let it warm up to operating temp. When I give it full throttle the same thing happens too...regardless of throttle level.
Is this a carb adjustment issue? and I need to adjust the carb under load? or is it water in the hydraulic transmission fluid or low level tranny fluid?
