(quoted from post at 17:58:36 04/15/15) Does a 1958 (#22249) 841 have 10 or 15 spline disc?
Thanks!
I believe that would be a 15 spline disc. From another post on this site comes this information:
A 641 with SN 14256 or below will have a 10 splined shaft. Above that number will have a 15 splined shaft. A quick way to check is if the clutch peddle pivots on the left side of the transmission it should be a tractor after SN14256 with 15 splines. If the clutch pivots off of the left brake shaft at the left front of the transmission, it would be before SN 14256.
I think the clutch disk is common on the 641 and 841. My 1958 641 uses the 15 spline disk.
Thanks, Mooboy!
The clutch is on the left on it's own pivot. I kind of suspected it would be a 15, but some vendors don't make it clear.
