5200 coming up on auction
Only some of the pictures came up for me for some reason.
Wonder if that's the same 5200 that was on Craig's list (Duluth?) a few months ago. That one was advertised as needing steering work as well.
The photo on the website is small but if you click on the link below it is pretty big.
It looks like it has the torque amplifier or whatever Ford called it.
Can't think of the name now.
click here
That's it.
Thanks
Edit:
Looking at it closer I'd say it has a 10 series BSD engine in it.
Has the extra cross hatching on the block and you can see the tag on the front of the valve cover.
Why the goofy vent tube out the side.
Also, did all 5000s keep the old style steering pump and reservoir or just the RCs?
Yes, it has the BSD engine. I noticed that by virtue of the stink tube on the side lol. I greatly prefer that over the front mounted tube where the fan blows it all over hell.. plus this way you can see how bad it's blowing at a glance.
Rod
AFAIK, the pump and reservoir was a running change on both the rc and ap models, some time in the '69-'70 model years.
Had the funky ford steering box. the uppershaft set over the lowershaft with fine splines and an clamp iirc... and it was prone to stripping out. parts for the box itself are not available. It was an early hydrostatic system again IIRC. About half of them I see have the shafts welded together. MOst of the 5000 or 7000 rc's that come through also have the lower links about worn into.. They were used long and hard apparently. Yet to see one with low hours like the all purpose models. Lots had aftermarket cabs and some even had the m&w turbo kits on the 5200s. Used one for about 10 years that way and it performed well after getting the steering issues fixed. Used parts are pretty far between. SOld a couple of 7200s with and without cabs.
According to the parts site, they switched to the p/s pump with the integrated reservoir in 1968 for the ag chassis 5000, but didn't switch on the row crop 5200 until 4/73. The serial number in that listing makes it an early 1970 tractor.
