tex prexhurst
I'm trying to set up a front snow plow on my 2000. I can use either the 2 way or 1 way ram, but I can't get it to work. The tractor has 2 controls (plus the 3pt control). I want to use the port(s) on the inside (the driver's left) of the valve. The IT manual says something about an allen screw that will convert a dual ation valve to a single action valve. I tried hitching up to the cyl with 2 lines, but it will only raise the plow, not lower it. I then tried it with the front port to the cyl but that did not move anything. The IT manual seems to say that the front port is the pressure port. Where am I going wrong. I took some pictures, but I can't figure how to link to them on photobucket.
Thanks.
Tex
