dwag
Got the remote valve kit today from Tisco, single spool w/detent.($$$$) Valve and hoses fit good, however coupler mtg bracket that bolts to seat mounting (T shaped) rests on 3rd link bracket before being fully mounted. Wrong bracket? Heat and bend to fit? Will call tech service tomorrow but kinda anxious for an answer. Some brackets I've seen mount on axle hsg bolts. john
(quoted from post at 17:35:24 04/09/15) Got the remote valve kit today from Tisco, single spool w/detent.($$$$) Valve and hoses fit good, however coupler mtg bracket that bolts to seat mounting (T shaped) rests on 3rd link bracket before being fully mounted. Wrong bracket? Heat and bend to fit? Will call tech service tomorrow but kinda anxious for an answer. Some brackets I've seen mount on axle hsg bolts. john
You could just drill some new holes and move the bracket forward enough to clear the top link bracket.
Mark
Can heat bracket up and bend in a couple places also but will talk to Tisco tech first. Might be able to swap out brackets if another is available. Will post what I learn.
