front weights
That is the style I have on my 64 4000.
Only problem with them is that they have to come off every time you dismount the wheel.
The hub will not come thru the center.
So every time you have a flat, you have to dismount the weights, then dismount the tire.
After you fix the flat, then you have to remount the tire then mount the weights afterward.
Easy to pinch a finger between the weights when mounting them upright.
Other than that. They are great!
That is a very reasonable price too!
Keith
similar to the ones i got for my 4600 from a scrap dealer.
I saw a Ford in an ad recently that had those weights mounted on the outside of the front wheels, inverted so that the larger diameter portion stuck out away from the wheel and I thought to myself at the time that they must have been weights from some other tractor that the owner had found a way to make them fit, but as soon as I saw the pictures here I realized that the he was either too lazy to mount them properly or didn't know how they were supposed to mount.
