Charlie T in VA
I was using my 3000 dsl, and it started to sputter out. I cut it off and found out it was almost out of fuel. I added approx 2-3 gal of fuel to the tractor. Tried to restart no go.
When you bleed the air out of the injector pump do you loosen the large bolt on top of the injector pump???? Trying to get the air out. I have pumped the lever and have fuel in the filters. What else is there to do??? Thanks Charlie
