I recently aquired a 1963 ford 4000 tractor. Serial # 12764
The electrical wiring is a mess and the tractor has sat out in the weather for 4 years. However after several hours of work the tractor is now running. Transmission is a 5 speed and seems to works fine. The creamy white liquid on the dipstick on the side of the tractor reveals that there is water in the hydraulics as they are not working with the pto engaged. Was hoping someone can tell me some info on this model tractor. Are the Trans, hyd, differential seperate or is this a common sump. What is the best fluid to use after I drain this fluid out. How do I know if this tractor has live pto or transmission pto.
Thanks
Gerald
Thanks
Gerald
