Ford 601 wiring 6v positive ground
cyljock
Hello. I'm in the process of removing all the cobbled wiring on the tractor, and wanting to build a new harnss. What is the recommendation on wire sizes (gauge) to use? I was able to locate a replacement pilot light P/N PL-20-RC and will use a #55 bulb instead of the supplied #53. Also the wiring diagram is showing a in line fuse for for the fuel gauge. Any idea what amperage fuse this calls for? Thanks for your help.
14awg will be fine for anything other than starting, charging or glow plugs.
Fuses protect wiring.
Wire size tells you max fuse size, however this is an extremely low amp circuit. Not sure if you are using buss fuse or not but hard to find
smaller than 5 in a multi pack on store shelves.
