Plant Doc
3400 3 cyl diesel was running good all winter. Sat for two weeks without being run and I went to start it yesterday and the motor was locked up tight. Removed starter and tried turning with bar on flywheel both forward and backward with no success. Removed hydraulic pump thinking maybe something binding in pump and still locked tight. Drained oil to check for water, no water in oil. Drained water, no oil in water. Pull all three injector and still can not turn over. Now what? This motor is a factor reman 4 years ago. It has approximately 1600 hrs on new engine. Any ideas?
That may be a possibility, but I doubt the clutch would sick that tightly in 14 days and this tractor was kept inside in a heated garage. I will take a look at your suggestion in the morning. Thank you.
