I posted a few days ago about 8000 loosing oil pressure. I took the freeze out plug under the oil filter out hoping to be able to tell if the drive was stripped but I'm assuming it would be on the lower end of the shaft if it was. I cranked the engine over a few times with the filter off and noticed that it's pumping oil some but no pressure. Would it still pump oil if the oil pump drive was stripped or should I look somewhere else for the problem? Also will that drive pull out of that hole under the filter or is it attached bye something else to the pump? I've got a manual ordered but it'll be a few days before I get it.
