gears
So while my engine is at the machine shop I'm cleaning up the rest of the chassis and found a largeish puddle of lube between the trans drain plug and the rear end drain plug - looks to me like it's the brake cross shaft where it goes through. Is this common? There's no discernible play in the shaft so I think the bushings are fine. Did my 47 yr old seals just decide enough was enough?
Looks like the pedal assembly comes apart and the shaft pulls out the pedal side on the right, clean the shaft, replace the seals and I'm good right?
