64frd4000ind
Well, It worked fine, no leaks before I did the tractor split to change the engine crank.
Now after its mated back together, today we finally got to fire the engine for the first time.
Got excellent engine oil pressure.
BUT while the engine is running, I have a steady stream of hydraulic oil coming out the weep hole with the cotter pin in it in the bellhousing.
I didn't do anything to the transmission while it was apart, other than cleaning the gunk out of the bellhousing.
So is it likely that my input shaft seal has dried out and is now leaking? or do I have bigger Issues?
I haven't tried to put it in gear yet, assuming the oil is coming from the SOS, however it is taking a long time to get all the air worked out of the hydraulic pump on the side of the motor, and it seems to leak a little oil where the hyd pump connects to the cam gear on the side of the motor. I did put a new gasket there when reinstalling everything.
wondering if I need to loosen the hyd pump up re-seat everything again to stop that leak.
My other question is could the hyd pump be leaking into the bellhousing through the manifold somehow?
Sure wish I had a scope about now, so I could go through one of the attachment bolt holes and see whats going on inside for sure.
Tonight went form an extreme high of getting to hear it run, and run well, to an extreme low of where the heck is that oil coming from...
