wheel weights
steve19438
just bought these.
Those are the same ones that are on my 640 that I posted in your other post. Did you get the lug nut adapters for them. How many total did you get?
kirk
seller says I got everything. lug nut adapters and bolts for the weights plus two mounting plates and six weights. I have only seen the two pics he sent me. gonna meet him in Morgantown next week. I hope my leap of faith does not bite in the butt. no money transferred yet.
Hello Steve,
As long as the lug nut fit your TO, as I stated in previous post, you should be Ok. If I remember correctly when I mounted mine they are about 100 lbs each and mounting plate about 125 lbs. You will have over 600 lbs with your 6 weights. You can always leave a couple off if you don't need that much weight. Something to consider when mounting is to put the next set of bolts for the next plate in so if you want to add another plate you won't have to take the previous plate off to mount the bolts.
Off topic. Our show at Washington crossing this year is going to be a Ford feature. Any chance you could bring down your offset for the show?
Kirk
Kirk,
I'm interested in attending your show at Washington Crossing. Can you post the details, date, location, etc.?
Sean,
Here's is the website for the show. It's usually
held the third weekend of sept. It's a ford feature
so hoping to have a lot of fords there. There are
antique cars trucks motorcycles, the caterpillar
group, Hit and miss engines and a swap meet. It
starts on a Friday and goes thru sunday. If you go
stop by and said hello.
Kirk
show website
Kirk, Thanks. I bookmarked that link and will be looking for updates on this year's show. I hope to see you there.
Nice!
Just pulled one of my sets the other weekend. Here's some pics from it in case you need. Would like to find some extra plates for mine one day.
Good Luck.
Tony
