On the fully hydrostatic steering, when plowing, at you work you way down the row, the steering wheel will eventually works it way to the left, more and more... Especially if you have a spinner on the steering wheel, it will start say at the 9 oclock position and end up at 3 oclock by the time you at the end and turning around... I have seen it especially on the 7710 series but the 6700 does it as well... Is there an explanation for this... maybe the way the power is fed into the steering motor or the wheels or toein pulls a bit one way over the other, tire wear on the front end???? I know when you kill the engine if your holding the steering wheel you can feel it kick/ease a tiny bit one way.
A customer was asking me to explain it, and all I can say, is that they all do it. Got to be a better explanation....
Apparently my photos are from down under.
Thanks in advance.
Thanks in advance.
