Fluid recomendations
I have a field found 841 with loader i'm in the process of reviving and i was surprised to read in my reproduction owners manual that the rear end and transmission use a different fluid. I'm used to the N's with the 80-90 supplying both sections. This tractor also has power steering. My question is what type of transmission/hydrolic lubricant and power steering fluid? Thanks in advance
Bob
53-64 machines have seperate trans, Hyds, and diffy sumps.
Gear oil can be put in trans and diffy, and utf in Hyds and power steering... or run utf in all.
Get a utf meeting m2c134 spec.
Run that in the loader too!
I own an 841 and run ATF in the power steering. I tried the UTF fluid once and it did not work well in the power steering. As for the hyds, rear end and transmission I run the UTF as Sound says
