Our 7610 has dual fuel tanks and right now the
fuel gauge and temp gauge don't work quite
right (temp gauge) or at all (fuel gauge). I
am guessing the problem with the fuel gauge is
because it is an aftermarket dash that isn't
designed for dual tanks. My question is if I
buy another dash cluster for it, can I buy the
one made for a single tank and only hook up the
aux tank fuel level sender, since it will read
full until the top tank is empty and starts to
drop the level in the lower tank, which is all
I need to know to know if I am going to run
empty. New holland wants around $600 for a
whole new dash assembly with the dual tank fuel
gauge, or I could buy one for a single tank and
replace the gauge with a dual tank fuel gauge
for a little over half that. However, you can
buy the aftermarket clusters for about $100.
Also, is there anyone that makes wiring
harnesses for these tractors outside of NH?
They want about $1000 for the main harness.
Hurst
Hurst
