was working the 3600 today, running perfectly fine, shut the engine off, got back on 20 minutes later, and it will not fire off. I checked fuel at filter bleed-flows freely, checked fuel at pump bleed-flows freely, cracked lines at injectors while cranking-NO FUEL at injectors. I've bled the injectors on this tractor before after changing filters and it only takes 10-15 seconds and I can get it to fire. but i cranked it several times off and on for minutes, and NO fuel at injectors.
Its a cav pump. I triple checked the shut off cable, and lever 'is' in the open position- and I have the throttle wide open. Is something stuck inside? Is the pump dead?
any help would be appreciated,
thanks,
david
thanks,
david
