Pto leak part 3
Rancher Rick
New User
Well I dug into the 600 to checkout rivets I found took out differental missing 2 is there suppose to have play cause rivets aren't tight need some info
Either drill out the rest of the rivets or use a fine cutoff wheel to cut the heads off. Since it's still together, I would be replacing the rivets withe the bolts and nuts as you go so it is never completely apart, easier to keep things lined up that way.
You are very lucky to find this before it failed! There could have been a lot of wallowed out holes, along with loosing the use of the tractor when you really needed to get something done.
Great pic, now I see how a nut &bolt just holds the whole diff together - I'd thought the gear bolted on like an automotive setup.
