So, I've got the new (to me) 641 D home. I've been busy at work, but I've had some time to play around with it a little. This is my first tractor, and I'm having a lot of fun already!
I want to change all the fluids. The previous owner "Couldn't remember" when it had been done last, so I would take that to mean probably not anytime in the recent past. I'd rather be safe than sorry.
I've been doing some research as to what to use. The engine is in pretty good shape, starts right up, has just a touch of white smoke when running, which clears up once the engine warms (about 2-3 mins or so).
1) Crankcase Oil- I have a 144 Diesel. The Owners Manual says to use a SAE 20w?
2) Oil Filter- I have a Screw-on type, Mine is a DW1A, which is equivalent to a Fram PH8A.... Any suggestions as to what filter to use?
3) Trans/Rear End- Manual says a SAE 80W Mild Pressure extreme lubricant.
4) Hydraulic- M-4864-A is what the manual specifies. I've read all kinds of discussions about what to use- and am confused!
5) Fuel Filter- NAPA 3165 is on there. Plan to use the same.
I'll also check the level of steering lube, and check out the fuel tank.
Anything I'm missing?
ANY tips greatly appreciated... I'm new to this tractor (and DIESEL) thing
-Andrew
-Andrew
