catfish1957
New User
1960 801 diesel. So far, injectors rebuilt, injector pump rebuilt, re-ringed and head job with new valves, guides, and springs. All external fuel leaks resolved.
Problem: Set flywheel at 18 degrees but the pump marks will not line up. Not enough room in base slots. When pump marks are lined, the most I can get is 4 degrees BTDC. Heavy grayish to bluish smoke which lightens up with more rpms and really rough running. I need help.
