leaking pto
Rancher Tim
New User
I finally made it out to the barn today and noticed under my ford 600 there was about 1/2 cup of oil looks like the pto has a small leak what do you think could be leaking kinda like to have some idea before I dig into that one
Either the flange gasket or the PTO seal usually, though a 3pt lower pin can leak and run down too.
PTO shaft seal is an easy job if the bearing is good, and the wear ring hasn't migrated or worn a groove.. oil drain takes longer than the seal change.
Post back
I drained the ford tonight and found one of these in some muck on the bottom of oil reservoir
can you identify where these came from what am I looking for is the whole shaft suppose to just pull out sorry for rambling
I would have started a new thread on this.
More people might read it and not piggyback on Tim's thread which is unrelated.
That said, Which reservoir? The rear center housing?
They look like rivets that were used to attach the ring gear to the differential.
Wouldn't be the first time I've heard of those failing.
