Ford 2110 4x4
Gmc@2006
New User
I have recently purchased a ford 2110 4x4 and has leak
around oil pan. How do you remove or get to the oil pan on
this the pan is formed around the front drive shaft seems that
there should be a way to drop drive shaft to get to oil pan any
help would be appreciated thanks
On that tractor you have to drop the front axle and slide it forward to remove the drive shaft. Take the four bolts out that hold the front asle pivots to the frame and jack the tractor up enough to clear the dowels then roll the front axle forward to remove the drive shaft.
Mark
