Looking for the output shaft and coupling sleeve for a 66 3500 SOS trans - anyone have one or have an idea where to find them? I'd expect most junkyard wouldn't want to mess with transmission internals but would just sell the trans whole.
<Coupling PN C5NN4777A, item 55 on FHN diagram 04A01>
I got this tractor with a blown motor and the coupling was disconnected for towing but it now looks like when I reengaged it after fixing the engine it didn't go on as far as it should have, (looks like the lever roll pin is sheared, so the lever was in the engaged position but sleeve wasn't all the way) with the result that it stripped out at least partially this weekend..... Looking through the side of the case I can tell that about 3/16" of the splines on the output shaft are gone, and I suspect corresponding damage to the sleeve splines. I think I can make it still work, but I'd prefer to replace both. Thankfully it looks like the output shaft would be easy to swap with the tractor split, and the sleeve would also be easy - just need to find replacements.
Thanks,
~John
Thanks,
~John
