841 power steerign cylnder tie rod end
Hi, all,
bought replacement PS cylinder, but the ball end that bolts to the lionk arm is incorrect. See attached pic. Any sources foe the 'correct' repalceemnt part?
thansk!
bill
Think I went through the same issue. Do not know how to link you to it... but check this site for my posting around July 28th of 2014. Subject was "identify correct 641 power steering cylinder tie rod end" or search for SStra under modern view and you should see that posting in my list of postings.
The one you bought I think is a C5NN3A3O2B part number and are to fit the hundred series.
I have not found a after market product that truly replaces the OEM 310788 or 309526.
When I checked, CNH could still get the old ones for about $200 so I located a used one at a tractor salvage yard. Check around or you may try Long Lang Tractor in PA they deal in old Ford parts.
Hope that helps
(quoted from post at 11:36:41 03/08/15) Hi, all,
thansk!
bill
I was looking around and bumped into this C5NN3A302B or CAPN3300A
