more weights?
Tom Fischer
New User
Hi
I set this 1958 641 up last winter with a KingKutter 84" rear blade + pie weights in back and the Ford wheel weights in front. Works pretty well, but would like maybe another 100 pounds on the front. Is there an easy way to do this? Seems if I get another set of front weights, (double them up) bolt them face to face on the fronwheel, something might shake loose.
Would like more weight in the front. What to do?
(quoted from post at 22:01:08 03/07/15) Hi
Front rubber is new. Don't know if it tubeless, but rather not put liquid in there. Couple of reasons. Backs are not loaded either.
To bad you do not have a front bumper on it. If you did you could hang suit case weight on the bumper
