vane pump gear
does anyone know where i can get a drive gear for the vane style pump, everyone i see advertised is for the piston pump
I see no email button and when I go to your profile and try to PM you it says that it is not open either.
Simply type my email address into the TO: field of whatever your email program happens to be. That can't fail.
[email protected]
Thanks,
Terry
P.S.
I'm using Modern View for this forum.
I would gladly sell you the pump, but my recommendation would be to explore TOHs conversion which will work better and rid yourself of an outdated pump that is expensive to repair if you can even find parts.
(quoted from post at 21:03:33 03/08/15) TOH?
Paul
The Old Hokie (Forum Guru)
http://windyridgefarm.us/
NAA Vane pump conversion kits
Pump hoses and fittings all for $350.
