3000 gas timing idler gear removal?
gears
ok, so is the timing idler gear LH thread or is it torqued 270* past 300 ft/lbs!?
Snapon 6100 won't budge it and before I break out the cheaters I thought I'd ask. (of course I'm posting before I dig through the manual - I left it at work).
Wack the head of the bolt. Give it a pretty good
hit. Vibration will sometimes knock a stuck bolt
loose.
Manual (Ford service) simply lists it as "self locking bolt" torque to spec on page 68 = 100-105ft/lb
I'll give it a whack and try a breaker bar on it.
