Ford 8n Intake exhaust valve Tappet Setting
Rfarms
What is the correct valve Setting on a ford 8n? it Has the Adjustable tappets. The manual Says 00.10 To 00.12 for intake &00.14 to 00.16 on exhaust. others Say 00.16 on both. im confused. thanks in advance
0.010-14 is correct and that is set cold. And 0.014-16 is also correct. The variable of all that makes little difference. Me I tend to set them on the bigger setting due to the fact as the valves wear the gap closes up slowly
