FEL pump drive attachment
gears
Anyone got a front pump drive attachment for a 3000 series?
I'm looking for the hub that bolts to the front crank pulley. I have a LH thread drive shaft from an N setup, would it be advisable to use this or go with a spline setup?
The pump is a keyed shaft and I'll have to come up with a coupler.
Just curious what this type of assembly sells for. Or if anyone has one lying around.
Thanks
I prefer the spline type but then I can not really compare since that is all I have ever had. As for where to find that stuff most any tractor dealer should have it or be able to get it. Last one I got cost me around $60 but that was a number of years ago
How'd you find it? I searched the ford 3000 parts, looked all through the hydraulic section and did a general search.
