My '64 4000 Diesel tractor absolutely refuses to start. It'll crank over strongly, and the compression is there, but no start at all. I've checked the glow plugs, and have tried to start it both with and w/o the glow plugs "on" (it usually starts [i:dd57082549]without [/i:dd57082549]power to them, when the outside temp is above 35*F!). There is fuel in the tank, plenty of amperage available at the battery, the cables are clean, and there is power to the gauges and lights.
The top end has 42.5 hours on it after it was gone through four years ago. It's a leaky critter, though, as I have a couple of fluid leaks around the tractor.
What say you guys???
