3000 no hydraulics
toby
1973 Ford 3000 SOS transmission.
The transmission is working fine but no hydraulics today. Three point or scv valves not working. Where do I start??
Sound Guy<
I now understand. Burping the pump was the use of heat on the tractor side. The scv and 3 point started to work (17 degrees). Next step is to ???
I would guess:
Pull the top
check and or change strainer
replace all rubber parts of suction line to the pump?
Anything I am missing??
Toby
The fluid did not see to be white or cloudy. I bet that could be a problem. Could change fluid first before pulling the top.
Toby
With cold weather, moisture and filters? I'd add in a few pints of 90% alcohol in there runner around the yard till warmed and working, get that flowing, then drain and refill. A lil atf and diesel tossed in to thin it a hair and suspend anything not solvated could help too.
