3000 foot throttle pics?
gears
Anyone got a pic of an installed foot throttle on a 3cyl gas? My 3400 has the pedal and such but is missing the connecting link from the pedal to the throttle shaft on the column.
I have a couple of photos here but my tractor is up north so this is all I can give you.
These are for a diesel.
Try searching on foot throttle. There was a recent post on this
same subject that may shed some light. End of Jan this year I think. Worth a try at least.
I had a question about this for my tractor, but mine was the older 64 model, I don't know that they are the same, but there were a lot of pictures shared.
thanks guys, I did see those other posts & pics, the pre '65 setup is totally different with that little rotary bell crank setup. Hobo - that ebay one looks the ticket, I just couldn't place which rod goes where.
UD, you've nailed it. That rod is the one I'm missing, goes from the pedal actuator to that slip collar with 2 ball studs on the throttle shaft. I think I can fab that up with an old N spring-cup and a clevis on the other end. Put in that 15* bend and I should be golden. Once I get the motor done that is.....
thanks all!
kg4ajk if you've got a pic of that rod UD posted attached to the tractor that'd be good. I believe the top rod/ball goes from the gov to the throttle and the lower ball is for the foot pedal rod.
[i:654c4848f0]"I believe the top rod/ball goes from the gov to the throttle and the lower ball is for the foot pedal rod." [/i:654c4848f0]
Just the opposite. The upper one is a much bigger ball and goes to the foot pedal.
I finally found that other photo I knew I had.
Photobucket used to have a search function where you could search your own pictures but they eliminated it.
I have nearly 500 pictures stored there in a bunch of different folders so a picture can sometimes be hard to find.
Thanks UD it's only been a few weeks since I yanked the carb & linkage off, you'd think I'd remember that sort of thing.
They say something starts to go as you get older but darned if I can remember what it is!
Went to the farm this weekend and forgot yo take pictures, see UD got it for you. If you need more let me know.
