Tisco Seat Cushion Question - Tony?
I have a question on the Tisco seat cushions if found through Tractor Supply Co.
Tisco Back Rest Cushion, 363219R91
Tisco Seat Cushion, 363220R91
Will those fit the Deluxe Seat Frame for the 64' Ford Industrial tractors like mine?
I need a set too but don't think this is it. Does your seat frame
look like this? If you find the correct cushions I would
appreciate knowing.
Thanks
Thats what my frame looks like, I haven't had any luck finding the exact cushions that belong on it. The back cushion on it was off of an IH, and the seat cushion was a lawnmower formed seat when I got the tractor.
The ford style cushions that fit the frame are no longer available, even YT is out of stock on them, I can't seem to find them anywhere, and the few places that did list a price it was about $80 each for them, but they were out of stock.
I just happened to come across these two cushions on the TSC web site, they are Tisco, was hoping Tony could let us know if they would fit the frame.
I know Rick was looking for some also, I think he said he needed frames and all though for two tractors.
Yeh, I hear you, hard to get. I have two of
these style tractors and have some pretty
roached out remnants of the original seats up
in the barn. I have been considering two
options. 1. Have someone rebuild cushions
from the examples I have which would then be
very close to original, or 2. go to some other
style aftermarket seat with similar design but
with armrests. My preference is original (just
the way I am) I like all original if at all
possible.
I'm not so much on it has to be original, I just can't see getting rid of a perfectly good frame that should hold fairly generic size/shape cushions....
I have looked at a couple of aftermarket seats, just trying to see what I can find for the old frame first.
I'm to the point of starting to reassemble the tractor, and if all goes well, I will need the seat in 2-3 weeks... if I can't find cushions by then, I guess I'll go for the aftermarket seat.
Nice picture and nice tractor. My 4030 Industrial's are the earlier version with the round medallion and 600/800 style grille. Other than that I think they are pretty much the same tractor.
Another option is to get another seat off another tractor that's not exactly the same but similar. I've got one on my 4000 HD that I got off a massey combine. It's a lot better than the boat seat that came with the tractor.
Kirk
Hello Keith , Those Tisco part numbers look like IH part numbers and I know IH did use a similar seat even one that used the same rubber springs as the Rest-O-Ride seat . I will have to look at them and get some dimensions to see if they will fit . Thanks Tony
Hello Norm , Your 4030's have the 801 ONLY egg crate type grille NOT 600/800 grille which are completely different . Thanks Tony
