looking at a ts100 with electric 4 range and 16 speed shifters.
If you shift, a yellow light comes on showing a "Book" and it beeps...
If I take my foot and pull throttle pedal up and idle it down, it will shift fine. Its idling fast.
Whats up with that?
Left lever is forward, neutral, reverse. next lever is two ranges, and the next lever is two ranges. The middle lever has the up and down 4 ranges on it.
Are these tractors problematic? Its also a 4wd... that part seems to work ok... thoughts????
Thanks
Whats up with that?
Thanks
