Carb help needed.
Howlemup
New User
I have a Marvel Schebler TSX 428 carb off of 53 ford Jubilee. I started to rebuild the carb and quickly found that I am missing the
Power adjusting needle seat. I am in desperate need of a replacement needle seat. I have had no luck finding one online and am hoping someone here can help me find one new or used.
Thanks in advance for the help.
(quoted from post at 03:35:23 02/14/15) I have a Marvel Schebler TSX 428 carb off of 53 ford Jubilee. I started to rebuild the carb and quickly found that I am missing the
ust a small pressed in brass tube. Not a screw in part that looks like typical jets. If that is what you refer to, you may be in for innovation because probably not available.
Kind of difficult to get a good picture, but I tried.
Thanks everyone. You are all right! I was following the diagram that was sent with my rebuild kit and it shows a removable seat. You were right though, my model doesn't have a removable seat. Thanks again for all the excellent advice and quick response.
