Ford 800 series backfiring
marmon77
I have a Ford 800 series , I can start it up it will run for a few minutes backfiring at times the it will shut off. I choke it start it again and it will do the same thing. Your thoughts please
You have a lean condition. If it will run with the choke partially pulled out and smooth out, it is not getting enough fuel.
Check fuel filter first. Then clean carb.
I cleaned filter drained bowl on carb. looks to be running rich. I have black smoke coming out and it still backfires.
