Front hydraulic pump drive shaft
The front pump shaft on my 850 gave up today. The splines were kind of beat up the last time I had it apart and now it's stripped. I expect to replace both the shaft and the adapter on the crankshaft pulley. The question is; where do I look for one. I know I need to pull it out and measure it, I just want to know who might have them. Thanks
Most any good tractor dealer should be able to get you one. This site may even sell them. As of doing it yes always replace both the shaft and hub or you will be replacing the shaft again real soon I learned that the hard way. I have an old hub and shaft right here on the floor from my 841. It is a 6 spline hub and the shaft is 9-1/8 inch long if that helps any. Same hub and shaft is used on my 8N ford with loader/backhoe
