Gasket needed for 841 hydraulic lift cylinder
I am in need of a gasket for my hydraulic lift cylinder. The gasket is for the "hydraulic lift valve, rear, retainer"; part number NCA901B. (good number) I have spent most of today trying to locate one. I have tried this site along with every tractor parts store I know of and probably 10 CNH shops. Any help would be greatly appreciated. "OR" I can make one. However, am not sure about the thickness. Any ideas on the thickness? Thank you, and any help would be appreciated.
I was also under that impression. I discussed this with a yt sales rep about this today. this part nor the two O-rings for the exhaust and pressure tubes comes with the set. I purchased the set from them about two weeks ago.
Odd but then one never knows now days. Should be alb to get them from a New Holland/Ford dealer also
I have a 641 and a 860 running without the gasket. What is the exact purpose of this gasket? Seal the unloading valve chamber better?
(quoted from post at 21:23:46 02/09/15) I have a 641 and a 860 running without the gasket. What is the exact purpose of this gasket? Seal the unloading valve chamber better?
don't see any reason for it either, Wayne? Don't see it sealing anything.
