I'm having a challenge fitting my Duo-Trac tire chains on my 445C with 16.9 x 24 Titan R-4 tires on one-piece rims. I have about 1 inch of clearance between the widest part of the tire body and the loader frame. There is about 2-1/4" inches of clearance between the outer part of the tire by the lugs and the loader frame.
I tried offsetting the chains to the outside, by dropping zero side links on the inside and dropping 5 links on the outside, and using 4 heavy duty bungee cords to pull any slack to the outside. Most of the inner chain rail rides on the outer part of the tire and clears the loader frame, but some parts of the chain side links ride lower on wider part of the tire body and contact the loader frame, causing wear on the side connectors.
The 15" wide rims have 9-1/2" of offset on the inside and 5" inset on the outside. If I swap the tires from side to side, I will gain about 5" of width on each side, making the tractor 10" wider, and wider than the loader bucket.
I can find hub centric 2" wheel spacers from BORA. but they are pricey at $400 per pair. My 3/4" diameter wheel lugs have regular nuts with washers, and only about 1/8" of thread beyond the nut so a ring type wheel spacer is not an option.
Any ideas?
Thank you in advance.
Guy
Any ideas?
Guy
