Greetings, I have a 1956 ford 800 tractor that was converted 5 years ago to 12v. Generally speaking it runs fine. In august, I replaced the solenoid because the terminals were zapped. After that the thing ran great. I have been using it to push snow without fail. Over the last week, I noticed it starting to have some starting problems and I cant figure out what is going on. Generally, my process is, I open up the gas valve set the throttle to about 50% and hold down the clutch and push the start button... click. thats all she does. So, then I start to get creative. I'll put it in 5th gear, rock it back and forth a couple times and try starting it again. Sometimes that works. but boy does it crank over slow but once its running, it runs smooth.
Then I had to take it to the next level when the rocking didnt work. I actually took off the starter and inspected it, gears on the starter look good and the crank gear in the engine looked fine. (Although it was dry, I wasnt sure if that area of the engine is supposed to have oil in it. I simply put the starter back on and tried again and it started fine, although it still cranked super slow.
Finally, yesterday, I thought it must be a battery problem, the battery is 5 years old. I took my old one to Autozaone and they tested it and said it tested fine, I described the problem and they said, maybe its not holding a charge. I got a new one and no change. Thankfully the nice people at autozone let me return it and get my old one back. So now I'm getting worried. The engine has enough oil, the transmission has enough oil. If I put it in 5th gear the engine rotates when I rock the wheels. I'm afraid that its the early signs of a seize.
I've been looking around a lot and may people point to the solenoid of valve compression. Since the solenoid is only 5 months old, I'm leaning away from replacing it, but it is way easier to replace that than adjust the valves.
I should note that it has been very frigid here the last few weeks, ranging from -10 to 20 degrees.
Any help would be greatly appreciated.
