Found the leak on mine, it wasn't at the injector itself but the return hose between injector 1 and 2 has a small hole it is weeping out of. I believe who ever did this and cut a lot of the hardlines and replaced with hose did not use a fuel hose for diesels as it is brown and oil soaked and needs to be replaced.
So my question is two fold, first question is what size is this return hose for a '68 (if my research is correct) Ford 3000 Diesel? My second question is what hose should I look for that will work with diesel fuel and not result in this issue coming up again.
