Stanadyne Fuel Pump
I have a Stanadyne diesel fuel pump model number 2252465 DBVCC429-144J
The head on it is locked up. Rebuild qute 1800.00
Can I replace this with an electric 12 volt diesel fuel pump?
If anyone has done this could you tell me what type to get and any pointers. Goes on a 901 Ford Powermaster.
There are no electric fuel pumps that will replace this pump to the best of my knowledge.
However, I'd think you should be able to find a salvage pump with a good head for much less than $1800.00
You will need another injection pump. Was the old head pressed apart to find out why it locked up? I would NOT just put on another pump until you know why it failed, or it may happen again.
Find a used core pump and use the head Assembly in your housing. Used core should run about 100-150 bucks, labor to build the pump and run on test stand 450. Should be able to have the pump running good for 550-650 bucks with warranty. I built two like this in the last couple months. Get a second opinion on the head. Some guys like everything to be perfect. I like it to be good enough to pass all tests on the stand. Sometimes this means using parts that are not perfect, but reusable. Some shops will work with you some wont. Call around. If no one will treat you right give me a call. I have saved hundreds of Roosa-Stanadyne pumps. Good luck,,, Al 231/757/0064
The link below is a search of Ebay using the term "Stanadyne DB Diesel Fuel Injection Pump Injector".
There are currently several rebuild services listed. They indicate that if the head is seized there will be additional charges and suggest you call them prior to purchasing the service.
Are you missing a "G" in the model number? If so, member ‘jdemaris’ gave a description of the model number in a previous post which may be helpful to you:
DBGVCC429-8AJ means:
DB stands for B model pump with die-cast housing
G stands for centrifugal governor
V stands for vertical mount
CC stands for counter clockwise rotation
4 stands for four cylinder engine use
29 stands for pump plungers that are .29" diameter
8AJ is an option package sold to Ford
Yes I did leave the G out sorry about that. I think the reason it seized is because we had got a "good deal" on some diesel. You couldn't see that it had a lot od sludge junk in it. Tractor will run if you spray in it. We cleaned out lines and changed filters. It was very nasty. The pump is now all apart (that's how it came back after repair shop gave quote). Ive called around here where I live wynne Arkansas but cant find any used pumps. If I find one like on ebay how will I know if it will work with my pump? Wont it have different numbers? Different brands? I will take some pics of what I have and see what you guys think we should do. Thanks so much for your help Teresa
Double check your option package number, it
looks like it should be 14AJ instead of 144J
based on the injection parts list.
The list indicates that the most popular option
package number for your tractor model (901) was
actually the 5AJ. It may be that both the
“5AJ” and “14AJ” options would work on your
tractor.
When searching for your injector model number
try breaking up the part number with spaces or
dashes such as "DBGVCC-429-14AJ" or "DBGVCC 429
5AJ".
Ford Tractor Injection Parts
The pump your looking for DBGFCC429-14AJ has been superseded to a DBO429-2933.. check flee-bay..
The main pumping unit/Head and Rotor P# is 20478
and the Drive shaft, P# is 10259
Hope this gives you alittle bit more searching info..
I can check on prices of the parts on Monday..
BUT 1800.00 is WAY out of line..
I'm almost certain I have a used dr.shaft, yours is probably broken..
I should have a used pump for a parts , also have some new NOS pumps we could barrow a head from. Should take a couple of days,,,, Al 231/757/0064
