Which Front Loader will fit my Ford 2000 tractor 1972 3 cyl?
SEB1
New User
I have a Ford 2000 from 1972, 3 cylinders, and I am looking to buy a Frond loader.
I want to know which Front Loader will fit?
I found a Ford Front Loader Old number 19 - 202 / New Ford Partnumber 703 model , Is it going to fit?
I found another one: Ford Front Loader 730 model, Is it going to fit?
I found another one: Ford Front Loader 724 model, Is it going to fit?
Thank you so much for your help :D !
The New Holland parts site shows that they made 2 different attaching kits for the 730 loader that were made specifically for the 3 cylinder 2000 & 3000 models.
They don't show a mounting kit for the 3 cylinder tractor models for either of the other loader models you mention, but the 724 loader was made from '55-'74, and the 703 was made from '59-'71 so either of those might fit as well.
On any of those models, if the loader wasn't previously mounted to a 3 cylinder 2000 or 3000 then you'll likely have to hunt up some mounting brackets or fabricate something.
freeman made loaders tp fit these tractorsthat work and fit as well as a ford loader if u can find a 3000 freeman loader whitch has a front pump it is as strong as any thiong u can find.
