white halftrack
Where to start.
I am working on a 3400 that I had purchased non running. We had the head rebuilt and while doing that we had pulled the separate power steering reservoir off. As preventative maintenance, we replace the hoses on the bottom of the reservoir, cleaned it and replaced the internal filter. We did not drain the rest of the system, but refilled the tank with the traveller UTF from TSC that matched the 134d. The tractor was in the warm shop and it started and ran well. Power steering was great. It has been ran for a couple of hours. My father let it sit out of the shop and when running it yesterday, it was spewing frothy oil out the top of the fill lid covering everything. Where would you start on this problem.? My thoughts are to drain the system after it gets thawed out by cracking the hoses at the cylinders to get everything out and then check my filter to see if it blew out.
Any ideas on where to head with this? I will check my hoses again.
Thanks
Jason
Thanks
Jason
