radara4077
I have my 841 Ford split at the clutch. In the process of sealing leaks, etc. I know the gasket between the back of the Sherman and the front transmission housing (the Sherman mounting bracket, I think is what it's called) is 1/64th material. I need to make two additional gaskets:
-The gasket in the Sherman where the input shaft enters the housing.
-The gasket for the hydraulic pump drive gear cover.
Are these two gaskets of the same 1/64th thickness?
Also, any tips for getting the hydraulic pump drive gear cover off? Someone in this tractor's past has apparently had that cover off and "sealed" it with a gob of that "blue stuff" (not sure of the official name). Now it's leaking, but the "blue stuff" is I think keeping me from easily popping that cover off.
Thanks in advance!
Thanks in advance!
