600 vane pump repl with a piston pump
diver7150
New User
I have a 1955 Ford 600 5 speed with a vane pump.
and I would like to replace the old vane pump with a piston pump. Will the old cast aluminum inlet/outlet manifold fit the piston pump?
Thanks for any advise
david in Michigan
(quoted from post at 22:00:42 01/27/15) I have a 1955 Ford 600 5 speed with a vane pump.
david in Michigan
No, the manifold will have to be changed also. Be sure you get the NCA933J manifold and not the 310878. The 310878 is for the "01" series tractors. A lot of used parts sellers think they are all the same and let you try to figure out why the bolt holes don't line up. A piston type pump and the NCA933J manifold is all you need. It will bolt right on.
david in Michigan
eleted
Not sure on a 600 but I just did it on an 860 and I had to change the manifold too. About 35 bucks if you shop around.
